NetApp Knowledge Base
SECD process gets into a loop because the SMDB table "cifs_lug_domain_object_sid_cache_db" containing illegal duplicate entry with "--"
139
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
ONTAP 9
Issue
CIFS access is affected because the SECD process gets to the loop state.
  • The Secd log shows:
Thu Aug 25 2022 02:47:15 +09:00 [kern_secd:info:12851] | [000.138.250]  ERR  : While populating source name 'DomainSidCache' DSMF next failed with error Loop
detected in next() for table cifs_lug_domain_object_sid_cache_db. Next on "xxx 1-119" returned "xxxx 1-119"..  { in populateStore() at src/include/secd_configuration_sources.h:522 }
Thu Aug 25 2022 02:47:15 +09:00 [kern_secd:info:12851] | [000.135.269]  ERR  : While syncing source name 'DomainSidCache' DSMF next failed with error Loop
detected in next() for table cifs_lug_domain_object_sid_cache_db. Next on "xxx 1-119" returned "xxxx 1-119"..  { in syncStore() at src/include/secd_configuration_sources.h:690 }
  • MGWD log shows:
00000015.0029b548 4bf3604b Mon Aug 22 2022 12:48:14 +09:00 [kern_mgwd:info:80872] Error: Loop detected in next() for table cifs_lug_domain_object_sid_cache_db. Next on "xxxx 4-514" returned "- -".
00000015.0029b549 4bf3604b Mon Aug 22 2022 12:48:14 +09:00 [kern_mgwd:info:80872] Error: Loop detected in next() for table cifs_lug_domain_object_sid_cache_db. Next on "xxxx 4-1888" returned "- -".
00000015.0029b54a 4bf3604b Mon Aug 22 2022 12:48:14 +09:00 [kern_mgwd:info:80872] Error: Loop detected in next() for table cifs_lug_domain_object_sid_cache_db. Next on "xxxx 4-1999" returned "- -".
New to NetApp?
  • Was this article helpful?
