NetApp Knowledge Base
ONTAP drive X318_HLBRE08TA07 failed with Failed-Unsupported status
751
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • DS212C disk shelves
  • X318_HLBRE08TA07 drives
  • ONTAP 9.7P8
Issue
  • When adding new DS212C disk shelves populated with X318_HLBRE08TA07 drives to the system, some of the drives are displayed with following status:
Cluster::> system node run -node <node name> -command sysconfig -a
07.0 : 0.0GB 0B/sect (Failed-Unsupported)
07.1 : 0.0GB 0B/sect (Failed-Unsupported)
07.2 : 0.0GB 0B/sect (Failed-Unsupported)
07.3 : 0.0GB 0B/sect (Failed-Unsupported)
07.4 : 0.0GB 0B/sect (Failed-Unsupported)
  • Messages such as the below can be observed on the system:
Sun Nov 22 12:07:42 +0100 [node-01: scsi_cmdblk_strthr_admin: scsi.cmd.pastTimeToLive:error]: Disk device 0a.07.0: request failed after try #1: cdb 0x12.
Sun Nov 22 12:07:42 +0100 [node-01: scsi_cmdblk_strthr_admin: disk.init.err.unsupported:error]: Disk 0b.07.0 is not recognized as a supported disk and cannot be used on this node.
Sun Nov 22 12:07:42 +0100 [node-01: scsi_cmdblk_strthr_admin: scsi.cmd.pastTimeToLive:error]: Disk device 0a.07.1: request failed after try #1: cdb 0x12.
Sun Nov 22 12:07:42 +0100 [node-01: scsi_cmdblk_strthr_admin: disk.init.err.unsupported:error]: Disk 0a.07.1 is not recognized as a supported disk and cannot be used on this node.
Sun Nov 22 12:07:42 +0100 [node-01: scsi_cmdblk_strthr_admin: scsi.cmd.pastTimeToLive:error]: Disk device 0a.07.2: request failed after try #1: cdb 0x12.
Sun Nov 22 12:07:42 +0100 [node-01: scsi_cmdblk_strthr_admin: disk.init.err.unsupported:error]: Disk 0a.07.2 is not recognized as a supported disk and cannot be used on this node.
New to NetApp?
