NetApp Knowledge Base
During ONTAP upgrade cluster network ports went down on FAS2552
807
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2552
  • ONTAP upgrade
  • Switchless cluster
Issue
  • During ONTAP upgrade the cluster network port goes down:
    cluster::> network port show
    e0e Cluster - down 9000 auto/auto -false
    e0f Cluster - down 9000 auto/auto - false
  • Storage failover giveback is not possible:
    cluster1::> storage failover show
                                  Takeover
    Node           Partner        Possible State Description
    cluster1-n1     cluster1-n2   false    Connected to cluster1-n2,
                                           Partial giveback, Takeover is not
                                           possible: The version of software
                                           running on each node of the SFO pair
                                           is incompatible, NVRAM log not
                                           synchronized
    cluster1-n2     cluster1-n1     -      Waiting for cluster applications to
                                           come online on the local node  \
                                           Offline applications: mgmt, vldb, vifmgr, bcomd, crs.
    2 entries were displayed.
    cluster1::> storage failover show-giveback
                   Partner Node         Aggregate         Giveback Status
    cluster1-n1   CFO Aggregates    Done  aggr1_DATA1      Not attempted yet
    Warning: Unable to list entries on node cluster1-n2. RPC: Couldn't make connection [from mgwd on node "cluster1-n1" (VSID: -1) to mgwd at 169.254.XX.YY]
New to NetApp?
