NetApp Knowledge Base
Console Port connections for ONTAP platforms Resolution guide
43,439
Visibility:
Votes:
36
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • AFF systems
  • FAS systems
  • Console Port
    • Micro-USB Serial
    • RJ45 Serial
The console ports enable you to manage the server when a network connection is not available, for example, during software installation, network troubleshooting or if the SP / BMC are not accessible.
Overview
The Console Port on current models is a RJ45 connection, similar to an Ethernet copper connection which is also RJ45.
  • Current NetApp models utilize 115200 Baud and previous models utilize 9600 Baud and will be noted in your platforms setup and configuration guide.
  • Each used 8 data bits, 1-Stop bit and No Parity.
How do you know which RJ45 port is the “console” port?
  • The icon above the RJ45 connector will say “Console” or will be marked: IOIOI.
RJ45 Serial Console port (IOIOI) Micro-USB Serial Console Port (IOIOI) Newer Products may include Both
AFF systems Console Port connections for ONTAP platforms Resolution guide Console Port connections for ONTAP platforms
HWU
Refer to  HWU to locate the console port and confirm the Baud rate for your specific platform
  1. Select the Platform / OS and show results
  2. On the Specifications table, select Onboard Ports & Cables  Console Port connections for ONTAP
  3. Review the Port Address and Supported Protocols column
The following is a collection of Knowledge articles that will assist you in finding your resolution.
New to NetApp?
