NetApp Knowledge Base
Cluster nodes show mixed-path cabling even though the system has all cables in place for Quad-path cabling
261
Visibility:
Votes:
0
Category:
not set
Specialty:
hw
Last Updated:
Applies to
  • FAS
  • AFF
Issue
A node may appear to have all of the cabling in place for Quad-Path HA, but the nodes will report as Mixed-Path in Sysconfig -a:
System ID: 0537152622 (Hostname1); partner ID: 0537152611 (hostname2)
    System Serial Number: 721748000127 (hostname)
    System Rev: A0
    System Storage Configuration: Mixed-Path
The nodes may also continuous Asyncd device scan done messages in the EMS logs:
[?] Sat Feb 20 10:41:53 -0600 [Hostname: pmcsas_asyncd_1: sas.adapter.debug:info]: params: {'debug_string': 'Asyncd device scan done.', 'adapterName': '10'}
[?] Sat Feb 20 10:43:24 -0600 [Hostname: pmcsas_asyncd_0: sas.adapter.debug:info]: params: {'debug_string': 'Asyncd device scan done.', 'adapterName': '9'}
[?] Sat Feb 20 10:44:53 -0600 [Hostname: pmcsas_asyncd_1: sas.adapter.debug:info]: params: {'debug_string': 'Asyncd device scan done.', 'adapterName': '10'}
[?] Sat Feb 20 10:46:24 -0600 [Hostname: pmcsas_asyncd_0: sas.adapter.debug:info]: params: {'debug_string': 'Asyncd device scan done.', 'adapterName': '9'}
[?] Sat Feb 20 10:47:53 -0600 [Hostname: pmcsas_asyncd_1: sas.adapter.debug:info]: params: {'debug_string': 'Asyncd device scan done.', 'adapterName': '10'}
[?] Sat Feb 20 10:49:24 -0600 [Hostname: pmcsas_asyncd_0: sas.adapter.debug:info]: params: {'debug_string': 'Asyncd device scan done.', 'adapterName': '9'}
[?] Sat Feb 20 10:50:53 -0600 [Hostname: pmcsas_asyncd_1: sas.adapter.debug:info]: params: {'debug_string': 'Asyncd device scan done.', 'adapterName': '10'}
[?] Sat Feb 20 10:52:24 -0600 [Hostname: pmcsas_asyncd_0: sas.adapter.debug:info]: params: {'debug_string': 'Asyncd device scan done.', 'adapterName': '9'}
[?] Sat Feb 20 10:53:53 -0600 [Hostname: pmcsas_asyncd_1: sas.adapter.debug:info]: params: {'debug_string': 'Asyncd device scan done.', 'adapterName': '10'}
[?] Sat Feb 20 10:55:24 -0600 [Hostname: pmcsas_asyncd_0: sas.adapter.debug:info]: params: {'debug_string': 'Asyncd device scan done.', 'adapterName': '9'}
New to NetApp?
