NetApp Knowledge Base
AFF-A300/FAS8200 node shutdown due a chassis over temperature
1,151
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8200
  • AFF-A300
  • ONTAP 9
Issue
  • Node shutdown due to chassis over-temperature while only reporting 88 Celsius:
[?] Mon Jul 26 09:32:44 -0400 [Node_1: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: CPU0 Temp Margin is critical high (88 C).
[?] Mon Jul 26 09:32:44 -0400 [Node_1: env_mgr: monitor.shutdown.chassisOverTemp:EMERGENCY]: Chassis temperature is too hot: CPU0 Temp Margin is critical high. System will be shutdown in 2 minutes
  • From the output of the events, all commands from the BMC, we see:
Record 710: Mon Jul 26 13:32:40 2021 [IPMI.notice]: 6301 | 02 | EVT: 015758f5 | CPU0_Temp_Margin | Assertion Event, "Upper Non-critical going high"
Record 711: Mon Jul 26 13:32:40 2021 [IPMI.notice]: 6401 | 02 | EVT: 015958ff | CPU0_Temp_Margin | Assertion Event, "Upper Critical going high"
Record 712: Mon Jul 26 13:32:44 2021 [IPMI.notice]: 6501 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted"
Record 713: Mon Jul 26 13:32:47 2021 [IPMI.notice]: 6601 | 02 | EVT: 8159c3ff | CPU0_Temp_Margin | Deassertion Event, "Upper Critical going high"
Record 714: Mon Jul 26 13:32:48 2021 [IPMI.notice]: 6701 | 02 | EVT: 8157c3f5 | CPU0_Temp_Margin | Deassertion Event, "Upper Non-critical going high"
Record 715: Mon Jul 26 13:33:02 2021 [IPMI.notice]: 6801 | 02 | EVT: 0300ffff | Attn_Sensor1 | Assertion Event, "State Deasserted"
Record 716: Mon Jul 26 13:34:40 2021 [IPMI.emergency]: triggered OS halt: Temperature critical
Record 717: Mon Jul 26 13:34:42 2021 [IPMI.notice]: 6901 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted"
Record 718: Mon Jul 26 13:34:56 2021 [IPMI.notice]: 6a01 | 02 | EVT: 0300ffff | Attn_Sensor1 | Assertion Event, "State Deasserted"
Record 719: Mon Jul 26 13:35:18 2021 [IPMI.notice]: 6b01 | 02 | EVT: 6f03ffff | Sensor 255 | Assertion Event, "Storage OS graceful shutdown"
New to NetApp?
