NetApp Knowledge Base
What are the Default Management Port IP addresses available on E-Series controllers?
9,535
Visibility:
Votes:
20
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
All E-Series platforms
Answer
The default management port IP addresses for each controller is shown below:
Default IP addresses for all platforms except EF600 running 11.60 or earlier:
Management Port  Controller A Controller B Subnet Mask
1 192.168.128.101 192.168.128.102 255.255.255.0
2 192.168.129.101 192.168.129.102
Note: Default IP addresses are in the form 192.168.XXX.10Y, where:
    XXX = 128 is the first port and 129 is the second port on a controller.
    Y      = 1 is for controller A and 2 is for controller B.
Default IP addresses for all platforms running 11.60.2 and later, or EF600 running 11.60 or later:
1 169.254.128.101 169.254.128.102 255.255.0.0
2 169.254.129.101 169.254.129.102
Note: Default IP addresses are in the form 169.254.XXX.10Y, where:
The subnet mask for these are running /16, not /24.
Port 2 on the controllers is reserved for Customer Support use only. It should not be used unless explicitly instructed and the default network settings of DHCP enabled should not be changed.
In case of a persistent network configuration issue, please contact NetApp Technical Support and reference this article for further assistance.
