NetApp Knowledge Base
Unreadable sectors on the E-series platforms on single drive
3,049
Visibility:
Votes:
1
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
NetApp E-Series
Issue
  • SANtricity reports Recovery GURU event:  Failure Entry 2: USM_UNREADABLE_SECTORS_EXIST-Recovery Failure Type Code: 75
  • The Major Event Log (MEL) log file or events under Support section of SANtricity System Manager report the following event:
Event type: 6700
Event category: Error
Priority: Critical
Description: Unreadable sector(s) detected data loss occurred
  • If AutoSupport is enabled, a Support Case will be automatically opened with subject: E-Series Notification from <array> (Unreadable sector(s) detected data loss occurred) CRITICAL
  • Furthermore, the following event may be logged if the threshold of unreadable sectors is reached:
Event type: 6703
Priority: Critical
Description: Overflow in unreadable sector database
New to NetApp?
