E-Series failed disk pool volumes on SANtricity OS pre-8.30.40.00 or pre-8.40.10 due to hardware failures
Applies to
- NetApp E-Series
- Dynamic Disk Pool (DDP)
- Controller Platforms: E26xx, E54xx, E55xx, E56xx, E28xx, E57xx and all associated EF-Series
- SANtricity OS Controller Software pre-8.30.40 (Not Equal)
- SANtricity OS Controller Software pre-8.40.10 (Not Equal)
Note: The SANtricity OS versions are considered within the same major release. For example, 8.30.50 is not included here.
Issue
- Failed volumes in dynamic disk pool(s) due to drive hardware failures.
- Volume failures due to power loss or connectivity issues are NOT considered hardware failures.
