NetApp Knowledge Base
Virtual Storage Console 4.x stops working after vCenter 5.5U3b update
359
Visibility:
Votes:
0
Category:
virtual-storage-console-for-vmware-vsphere
Specialty:
virt
Last Updated:
Applies to
  • ONTAP
  • FlexPod
Issue
A Virtual Storage Console (VSC)/SMVI 4.2.2 backup stops working with the following error:
Backups not listing HTTP 504: Gateway Timeout
Unable to backup systems from within VCenter.
  • Clicking the Backup and recovery Configuration option in the VSC plugin in VCenter displays an unable to connect to virtual storage console error
  • Running smvi backup list and other SMVI commands from the VSC server displays an error, and throws java exceptions about handshake failures and a connection been closed in the logs.
Specific issue (identified using Wireshark):
  • After the TCP three-way handshake, VSC by default sends an SSL client hello handshake proposing SSLv3 (0x0300) to vCenter.
  • vCenter then FIN, ACK the connection immediately, causing VSC to issue a fatal alert handshake failure packet back to vCenter, and the client programs to fail/error out. Forcing the client-initiated connections to negotiate at TLSv1 will resolve the issue.
New to NetApp?
