NetApp Knowledge Base
VASA Provider: SSL handshake between ESXi and VP fails with "certificate verify failed"
507
Visibility:
Votes:
2
Category:
netapp-vasa-provider
Specialty:
virt
Last Updated:
Applies to
  • ONTAP Tools for Vmware (OTV)
  • VASA Provider (VP)
  • vVols
  • VMware vSphere
Issue
  • Created vVol datastore is inaccessible and shows as 0 bytes
  •  vvold.log on ESXi hosts reports a SSL handshake error when communicating to VASA Provider:
2022-06-21T16:37:21.805Z warning vvold[2574793] [Originator@6876 sub=IO.Connection opID=xxxx] Failed to SSL handshake; SSL(<io_obj p:xxxxx,
h:14, <TCP 'xxx.xxx.xxx.xxx : 25608'>, <TCP '<vasa_provider_ip> : 9083'>>), e: 336134278(certificate verify failed), duration: 3msec
2022-06-21T16:37:21.805Z warning vvold[2574793] [Originator@6876 sub=HttpConnectionPool-000000 opID=xxxx] Failed to get pooled connection; <cs p:xxx, TCP:<vasa_provider_ip>:9083>, SSL(<io_obj p:xxxx, h:14, <TCP 'xxx.xxx.xxx.xxx : 25608'>, <TCP '<vasa_provider_ip> : 9083'>>), duration: 4msec, N7Vmacore3Ssl18SSLVerifyExceptionE(SSL Exception: Verification parameters:
--> PeerThumbprint: XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX
--> ExpectedThumbprint:
--> ExpectedPeerName: <vasa_provider_ip>
--> The remote host certificate has these problems:
--> * unable to get local issuer certificate)
New to NetApp?
