Storage Replication Adapter (SRA): Running and not registered with vSphere
- 537
- Visibility:
- Public
- Votes:
- 0
- Category:
- ontap-storage-replication-adapter
- Specialty:
- VIRT
- Last Updated:
Applies to
- Virtual storage system (VSC) 9.7.X
- ONTAP Tools for VMware vSphere (OTV) 9.8, 9.10
- Storage Replication Adapter (SRA) 9.7.X, 9.8, 9.10
Issue
When you open the OTV VM console, the login menu reports VASA Provider and SRA is running and not registered with vSphere.
Both VASA and SRA are running and enabled, and you can successfully run VASA and SRA operations.
Note: If any VASA or SRA operations are failing, then this KB article may not apply. Resolve any known VASA and SRA errors, then reevaluate the VM console status.
