SRM Operations Fail with Error About a Nonreplicated Configuration File
- 911
- Visibility:
- Public
- Votes:
- 2
- Category:
- ontap-storage-replication-adapter
- Specialty:
- virt
- Last Updated:
Applies to
VMware Storage Replication Manager (SRM)
Issue
When running several recovery or reprotect operations simultaneously in both directions, the operation fails with an error about a nonreplicated virtual machine configuration file:
The operation was only partially completed for the protection group 'Protection_Group' since a protected VM belonging to it was not successful in completing the operation. Cannot protect virtual machine 'VM1' because its config file '[VM1] VM1/VM1.vmx' is located on a non-replicated or non-protected datastore.
