Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
What is the lock manager protocol
598
Visibility:
Votes:
2
Category:
data-ontap-7
Specialty:
7dot
Last Updated:
Applies to
Data ONTAP 7 and earlier
Answer
The lock manager protocol supports both file-level and byte-range locking.
However, programs running on the UNIX system usually support only byte-range locking. Typically, the file locking process involves using a byte-range lock on a file, where the range of bytes is 0 to end of file.
File locking, called sharing, works with products similar to PC-NFS that are running on OSs similar to Microsoft, which support both byte-range locking and file locking.
Lock managers on UNIX Network File System (NFS) servers also support file locking and byte-range locking; however, most UNIX API\'s do not have any calls to specify the share modes when opening a file. UNIX NFS clients never make file-locking requests to an NFS server, only byte-range locking requests.
Additional Information
additionalInformation_text
Scan to view the article on your device
