Users not able to write on cifs shares when cifs audit and default NVE is enabled
Applies to
- ONTAP 9.7 and later
- CIFS
- NetApp Volume Encryption(NVE)
Issue
- Users not able to write on volume when cifs audit is enabled and default NVE is enabled for the vserver. Use below commands to verify if audit and default NVE is enabled:
::>vserver audit show -vserver SVM1
::>options -option-name encryption.data_at_rest_encryption.disable_by_default -vserver * -fields option-value
- Below error is seen on client:
