NetApp Knowledge Base
Total packet loss when pinging from cluster lif
2,009
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
ONTAP 9.x
Issue
Not all paths are reachable when attempting to test cluster network using Advanced privilege command:
::*> cluster ping-cluster -node node1
Host is node1
Getting addresses from network interface table...
Local = 10.254.231.102  10.254.91.42
Remote = 10.254.42.25   10.254.16.228
Ping status:
Basic connectivity succeeds on 2 path(s)
Basic connectivity fails on 2 path(s)
Detected 1500 byte MTU on 2 path(s):
Local 10.254.231.102 to Remote 10.254.16.228
Local 10.254.231.102 to Remote 10.254.42.25
Larger than PMTU communication succeeds on 2 path(s)
RPC status:
1 paths up, 0 paths down (tcp check)
1 paths up, 0 paths down (udp check)
The following EMS alert will be displayed:
EMS Alert:
vifmgr.cluscheck.droppedall: Total packet loss when pinging from cluster lif Cluster1_clus1 (node Cluster1) to cluster lif Cluster1_clus2 (node Cluster1).
New to NetApp?
