NetApp Knowledge Base
Takeover not possible: operator disabling takeover
3,548
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • Except MetroCluster IP solutions
Issue
Category Risk Details
HA Configuration
Storage failover is disabled.
Takeover is not possible because Storage failover is disabled.
  •  Run the storage failover command to determine the reason:
::>storage failover show –instance –node <node_name>
Example:
::> storage failover show -instance
                            Node: cluster1-01
                    Partner Name: cluster1-02
                   Node NVRAM ID: 5######
                Partner NVRAM ID: 5#####
                Takeover Enabled: true
                         HA Mode: ha
               Takeover Possible: false
    Reason Takeover not Possible: storage failover is disabled
  • Takeover not possible, as seen in the command output
::> storage failover show -node node01 -fields possible
node         possible
Node01 false
New to NetApp?
