NetApp Knowledge Base
Takeover not possible: NVRAM log not synchronized
14,461
Visibility:
Votes:
4
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
Issue
cluster1::> storage failover show
                              Takeover
Node           Partner        Possible State Description
cluster1-01    cluster1-02    true     Connected to cluster1-02
cluster1-02    cluster1-01    false    Connected to cluster1-01, Takeover is
                                       synchronized
2 entries were displayed.
  • Displaying the "Reason Takeover not Possible" field shows the following. Example:
cluster1::> storage failover show -fields reason
node           reason
cluster1-01    -
cluster1-02    "NVRAM log not synchronized"
  • Manual takeover is not possible. Example:
cluster1::> storage failover show -node cluster1-n1 -fields possible
node         possible
cluster1-01  false
  • In Fabric MetroCluster environments the following check output can be reported. Example
cluster1::> metrocluster check node show -instance
                            Node Name: cluster1-01
                        Type of Check: ha-mirroring-op-state
                             Cluster Name: cluster 1
                  Result of the Check: warning
Additional Information/Recovery Steps: Node's HA mirroring is not online. Verify the HA mirroring link status with the "metrocluster interconnect show" command, then bring the HA mirroring online with the "storage failover modify -node <node> -enabled true" command.
  • ONTAP Event Message System (EMS) is reporting. Example:
... [cluster1-01: statd: cf.takeover.disabled:alert]: HA mode, but takeover of partner is disabled due to reason : unsynchronized log.
New to NetApp?
