NetApp Knowledge Base
System configuration backup fails mgmtgwd.configbr.deleteFailed
434
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • system configuration backup
Issue
Log messages indicating failure of Backup Archive Creation:
cluster_backup_job::queue_local_backup_jobs - Failed to queue local job for %s Error: %s
cluster_backup_job::check_for_node_backups - Node: %s Backup Errored.
cluster_backup_job::check_for_node_backups - Failed to get job info for node: %s
cluster_backup_job::queue_local_backup_jobs - The node %s is not included in cluster backup
config_backup_create_handler::create_local_tarball - Failed to get the value of thebootarg.init.cfimagebase variable
config_backup_create_handler::create_snapshot - Failed to get rdb version
fill_node_backup_list - Could not find the directory %s to be backed-up
generate_cluster_conf_manifest - Could not determine the cluster uuid
generate_cluster_conf_manifest - Could not determine the software version
generate_node_conf_manifest - Could not determine the software version
generate_node_conf_manifest - Could not determine the hardware model
config_backup_restore_ops::create_dir - Failed to create the backup dir because of: %d
config_backup_restore_ops::create_dir - Found a non-directory in place of the backup dir
config_backup_restore_ops::create_dir - Found invalid permissions on backup dir
config_backup_create_handler::create_snapshot - root snapshot delete zapi failed:retval: %s
config_backup_restore_ops::clean_snapshots - failed to delete snapshot %s
config_backup_create_handler - failed to delete the temp dir %s
EMS message
Ems Identifier mgmtgwd.configbr.deleteFailed
Syslog Message The %s configuration backup %s on node %s cannot be deleted. Error: '%s'.
Severity ERROR
Description This message occurs when an old configuration backup cannot be deleted.
Corrective Action Ensure that the node is accessible and healthy. If necessary, delete the backup manually.
New to NetApp?
Scan to view the article on your device
