Storage Virtual Machines DR stop after a cluster reboot or an unplanned power outage
Applies to
- ONTAP 9.x
- Storage Virtual Machine Disaster Recovery (SVM DR)
Issue
- No data access to the SVM
- Down/Offline nfs/cifs/iscsi/fcp network interfaces (LIFs)
- Storage Virtual Machines (SVMs) are stopped after all nodes in an SVM DR are rebooted for any of the following:
- Environmental Shutdown (such as overtemp)
- Power maintenance or failure
- Equipment migration or other maintenance
- Other issues that result in a shut down of all nodes
- The destination SVM was not activated
- Attempting to start the Vservers result in the following error:
::> vserver start -vserver vserver1
Error: command failed: Failed to start Vserver "vserver1" because the management configuration for this Vserver is locked. Starting a locked Vserver can cause data access issues. To start the Vserver specify "-force".
- Attempting to modify any configuration within a Vserver results in the following error:
::> Volume snapshot policy modify -vserver "vserver1" -policy snap_Default -enabled false
Error: command failed: Changes to the Vserver configuration are not permitted:
the management configuration for the Vserver "vserver1" is locked.
