NetApp Knowledge Base
Root Volume Not Working Properly: Recovery Required - Autosupport Message
14,240
Visibility:
Votes:
5
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • callhome.root.vol.recovery.reqd
Event Summary
This AutoSupport message is triggered by the root.vol.recovery.reqd condition, where one or more of the following error messages are reported:
  • mgmtgwd.rootvol.recovery.new
  • mgmtgwd.rootvol.recovery.different
  • mgmtgwd.rootvol.recovery.changed
  • mgmtgwd.rootvol.recovery.takeover.changed
  • rdb.env.replicaCorrupt
  • rdb.corruption.reported
  • mgmtgwd.rootvol.recovery.low.space
Validate
  • During system boot one of the following messages will be displayed:
    **  SYSTEM MESSAGES  **
     The root volume is different than the one previously used by this node. This node is not fully operational. Contact support personnel for the root volume recovery procedures.
    Or
    Internal error: Cannot open corrupt replicated database. Automatic recovery
    attempt has failed or is disabled. Check the event logs for details. This node
  • An unexpected power outage or the nodes were not shutdown properly. ONTAP boots with the following message:
The contents of the root volume may have changed and the local management configuration may be inconsistent and/or the local management databases may be out of sync with the replicated databases. This node is not fully operational.
  • Accompanied by the error message "Cluster HA has not been configured"
 Warning: Cluster HA has not been configured. Cluster HA must be configured on
 a two-node cluster to ensure data access availability in the event of
 storage failover. Use the "cluster ha modify -configured true" command to configure cluster HA.
Event Log
event log show -severity * -message-name callhome*
[netapp-cluster-01: mgwd: callhome.root.vol.recovery.reqd:EMERGENCY]: Call home for ROOT VOLUME NOT WORKING PROPERLY: RECOVERY REQUIRED.
Resolution
  • Some Replicated Database (RDB) inconsistencies can be corrected automatically, in which case the message rdb.recovery.succeeded is emitted and no further action is required. If rdb.recovery.failed is logged, contact Support personnel for assistance, if required.
If the root volume is low on space, perform the following steps:
  1. Delete the old snapshot copies, delete unwanted files, and/or expand the root volume's capacity.
  2. After enough space is made available, reboot the controller.
    If required, contact Support personnel for assistance.
New to NetApp?
