NetApp Knowledge Base
Request to grow FlexGroup volume in ONTAP fails as the resulting volume size is greater than maximum size
1,039
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
Issue
Attempting to resize a FlexGroup fails with:
Request to grow FlexGroup volume failed because the resulting volume size is greater than maximum size. The maximum possible size is xxx.
Unable to set parameter '-max-autosize' to specified value because it is too large
New to NetApp?
