ONTAP volume move gets aborted due to data source error
Applies to
ONTAP 9
Issue
- Volume move fails with the following error:
cluster::> volume move show -vserver svm1 -volume vol1
Vserver Name: svm1
Volume Name: vol1
Actual Completion Time: Fri Oct 08 05:57:25 2021
Bytes Remaining: -
Destination Aggregate: aggr2
Detailed Status: Aborting Volume Move. Data Source Error.. Sender data source error.
Estimated Time of Completion: -
Managing Node: cluster-01
Percentage Complete: -
Move Phase: failed
Estimated Remaining Duration: -
Replication Throughput: 100.0MB/s
Duration of Move: 14:06:54
Source Aggregate: aggr1
Start Time of Move: Thu Oct 07 15:50:31 2021
Move State: failed
Is Source Volume Encrypted: false
Encryption Key ID of Source Volume:
Is Destination Volume Encrypted: false
Encryption Key ID of Destination Volume:
- The following messages can be seen in the EMS logs
Fri Oct 08 05:57:23 -0700 [cluster-01: repl_non_block: wafl.repl.src.inconsistent:error]: volume: vol1@vserver:22cf0566-ef65-11e4-a8b2-123478563412: WAFL metadata inconsistent due to disk errors. (vvbn:1105766759 level:0 file_type:15). Aborting transfer.
Fri Oct 08 05:57:25 -0700 [cluster-01: mgwd: mgmtgwd.jobmgr.jobcomplete.failure:info]: Job "Volume Move" [id 345714] (Move "vol1" in Vserver "svm1" to aggregate "aggr1") completed unsuccessfully: Aborting Volume Move. Data Source Error.. Sender data source error. (1).
- This may cause the volume to go WAFL inconsistent.
