Login fails when connecting to a ONTAP system using an ONTAPI or ZAPI based application
Applies to
- OnCommand Unified Manager 5.x / 6.x / 7.2 / 7.3 / 9.4
- Active IQ Unified Manager 9.6+
- OnCommand System Manager
- OnCommand Workflow Automation
- OnCommand API Services
- SnapCenter Plug-in for Oracle
- SnapCenter Server
- SnapCenter Plug-in for SQL
- SnapCenter Plug-in for UNIX
- SnapCenter Plug-in for SAP HANA
- SnapCenter Plug-in for VMware
- SnapCenter Plug-in Creator
- SnapCenter Plug-in for Microsoft Windows
- OnCommand Insight 7.x
- SnapCenter Plug-in for Exchange
- AV Connector
- Virtual Storage Console(VSC)
Issue
- Unable to log into Ontap using an application that leverages API calls in the form of ONTAPI and ZAPI, to log in to a clustered Data ONTAP over HTTP or HTTPS. The communication fails with the following error message:
Incorrect credentials, you may have entered invalid username or password.
- This can occur even if you have entered the correct username and password.
