Ifstat output reports long frames
Applies to
- All ONTAP versions
- All FAS/AFF platforms
Issue
- Long frames can be seen in the output of
ifstat
-- interface e1d (5 days, 13 hours, 44 minutes, 30 seconds) --
RECEIVE
Total frames: 438k | Frames/second: 1 | Total bytes: 32232k
Bytes/second: 67 | Total errors: 32047 | Errors/minute: 4
Total discards: 0 | Discards/minute: 0 | Multi/broadcast: 561k
Non-primary u/c: 0 | CRC errors: 0 | Runt frames: 0
Long frames: 32047 | Length errors: 0 | Alignment errors: 0
No buffer: 0 | Pause: 0 | Jumbo: 0
Noproto: 0 | Bus overruns: 0 | LRO segments: 0
LRO bytes: 0 | LRO6 segments: 0 | LRO6 bytes: 0
Bad UDP cksum: 0 | Bad UDP6 cksum: 0 | Bad TCP cksum: 0
Bad TCP6 cksum: 0 | Mcast v6 solicit: 0
- Either of the below events can be logged in EMS, depending on the ONTAP version
[Node1: vifmgr: vifmgr.cluscheck.crcerrors:alert]: Port e1d on node Node1 is reporting a high number of observed CRC errors.[Node1: vifmgr: vifmgr.cluscheck.crcerrors:alert]: Port e1d on node Node1 is reporting a high number of observed hardware errors, possibly CRC errors.
