NetApp Knowledge Base
How to set the correct SPN for a storage controller
10,406
Visibility:
Votes:
5
Category:
data-ontap-8
Specialty:
7dot
Last Updated:
Applies to
  • Data ONTAP 8 7-Mode
  • Data ONTAP 7 and earlier
  • There are times when the Service Principal Name (SPN) defined during CIFS Setup does not match the required SPN that a client attempts to look up.
    • This results in the following error being identified in the packet trace: KRB_ERR_S_PRINCIPAL_UNKNOWN
    • This in turn, causes the Microsoft Client to fall back and then use NTLM for authentication instead of Kerberos.
  • There are three common causes for this:
    • When CIFS setup was run on the storage controller, the value defined in options dns.domainname did not match the FQDN of the domain that was being joined.
    • When clients attempt to access the storage controller, they are using a Netbios Alias.
    • When clients attempt to access the storage controller, they are using a DNS Alias.
New to NetApp?
