NetApp Knowledge Base
How to set NTFS or Storage Level Access Guard security using SDDL files and fsecurity apply for Data ONTAP 7-mode
1,212
Visibility:
Votes:
1
Category:
data-ontap-8
Specialty:
7dot
Last Updated:
Applies to
Data ONTAP 7-mode
Security Descriptor Definition Language (SDDL) is the file used to define permissions on an NTFS volume, or the Storage Level Access Guard.
(SLAG) permissions on either Unix or NTFS style volumes. You can use the NetApp Secedit Tool to create an SDDL file, or you can use any text editor to create one by hand.
New to NetApp?
