NetApp Knowledge Base
How to enable volume inline deduplication on Non-AFF (All Flash FAS) aggregates
12,466
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • Non-AFF
  • NetApp ONTAP 9.2 and later versions
  • NetApp ONTAP Select (OTS) on HCI Storage
  • This article describes how to enable inline deduplication on Non-AFF (All Flash FAS) aggregates
  • On non-AFF systems, inline deduplication is disabled by default
  • To enable inline deduplication on volumes residing within an HDD/all-SSD (non-AFF) aggregate, the following hidden option needs to be set from the nodeshell on both nodes in the HA pair as shown in the procedure below
  • Due to CONTAP-505318 Netapp Support does not recommend to enable this feature on FAS70/90 platforms to avoid potential node disruption
New to NetApp?
