NetApp Knowledge Base
How to disable Multi-Admin Verification if MAV admin is unavailable
5,385
Visibility:
Votes:
5
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9.11.1 and later
Multi-Admin Verification (MAV) is a new security feature in ONTAP 9.11.1. When enabled, a protected set of commands is identified, which cannot be executed without explicit approval of one or more administrators with special MAV credentials. This prevents compromised, malicious, or inexperienced administrators from making undesirable changes or deleting data.
However, if the MAV admin account is compromised or unavailable this article describes how to recover. This procedure requires direct console access and is viewable by NetApp partners.
Please contact NetApp Technical Support or log into the NetApp Support Site to create a case. Reference this article for assistance with the solution.
  • The solution requires Diagnostic-level recovery.
  • The use of Diagnostic commands and recovery steps is potentially disruptive and should only be used with guidance from NetApp Support.
New to NetApp?
