NetApp Knowledge Base
How to configure no_root_squash
26,282
Visibility:
Votes:
7
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9
  • Data ONTAP 7
  • Some Linux NFS servers have an option called no_root_squash which disables the default behavior of squashing the root user
  • Root squashing is a security feature
    • NFS commands executed as the root user on the client will be considered as originating from the "anonymous" user
  • While this specific option is not supported it is possible to obtain the same effect with the "root" option in an export entry
New to NetApp?
