NetApp Knowledge Base
How to add lines to a configuration file on the storage system using wrfile. The command wrfile does not have an option to Exit without Saving
1,755
Visibility:
Votes:
1
Category:
data-ontap-8
Specialty:
7dot
Last Updated:
Applies to
  • CIFS
  • NFS
This article describes how to add lines to a configuration file on the storage system using wrfile.
  • No Common Internet File System Protocol (CIFS) or Network File System (NFS) access to the storage system, but the administrator needs to add an additional line to a configuration file on the storage system without editing the entire file.
  • Typically, when using the wrfile command, Ctrl-C is used to save changes, disregarding the following:read: error reading standard input: Interrupted system call.
    Other than Ctrl-C, there is no other key sequence available.
New to NetApp?
