NetApp Knowledge Base
How does Access Based Enumeration (ABE) work?
14,555
Visibility:
Votes:
9
Category:
ontap-9
Specialty:
nas
Last Updated:
1/23/2025, 3:41:15 PM
Applies to
  • ONTAP 9
  • Data ONTAP 8 7-Mode
Answer
  • When access-based enumeration (ABE) is enabled on a CIFS share, users who do not have permission to access a folder or file underneath it do not see these displayed in their environment.
    • The actual permissions on files and folders do not change, only visibility does.
    • ABE does not hide the share itself, it only hides the folders/files created under it, based on the access permissions.​​
    • If users or automated systems rely on the visibility of all files and folders for indexing or management purposes, ABE could disrupt these operations.
Note: There is no global option per-SVM, each share must have ABE enabled on it if required
  • Local administrators still have unrestricted enumeration
    • Members of the BUILTIN\Administrators group are granted unrestricted access to the local system
    • Thus, an account in this group would be able to enumerate the entire directory
  • By default, ABE is disabled
  • Enabling ABE
    • For Data ONTAP 8 7-Mode
      • cifs shares -change sharename -accessbasedenum
    • For ONTAP 9
      • ::> cifs share properties add -vserver <vserver> -share-name <share> -share-properties access-based-enumeration
  • Disabling ABE
      • cifs shares -change sharename -noaccessbasedenum
    • For ONTAP 9
      • ::> cifs share properties remove -vserver <vserver> -share-name <share> -share-properties access-based-enumeration
Additional Information
