NetApp Knowledge Base
How ONTAP implements SMB crediting
9,199
Visibility:
Votes:
9
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9.4 and later
  • SMB2 and higher
Answer
  • In ONTAP 9.4, throttling of SMB credits was implemented via a maximum credits configuration
    • Prior to 9.4, SMB clients were granted as many credits as they requested
    • By default, Cifs servers created with ONTAP 9.4-9.12 grants 128 credits per connection
    • By default, Cifs servers created with ONTAP 9.13+ grants 512 credits per connection
  • Display the current max-credits value:
cluster1::*> set -privilege advanced
cluster1::*> vserver cifs options show -vserver svm1 -fields max-credits
  • Modify max-credits value:
cluster1::*> vserver cifs options modify -vserver svm1 -max-credits 1024
Additional Information
  • Modified credit value will only take effect on new cifs sessions
  • SMB credits determine the number of outstanding simultaneous requests that the client can have on a particular connection.
  • The allowed range is between 2 and 8192
    • Default value (512 and above) typically does not need to be changed unless confirmed to be root cause or vendor states a specific number of credits are needed.
      • Follow client vendor recommendations if it differs from the default
    • While it is possible to set number of credits to 2, there have been reports that some clients start to misbehave with such a low setting
  • Recommendation from Support is to double the amount of credits as needed up to the max value.
  • As documented in this Microsoft Docs page, Performance tuning for SMB file servers, Windows defaults to 512 credits.
  • For assistance with disabling SMB crediting altogether, contact NetApp Technical Support and reference this article.
