NetApp Knowledge Base
Cluster peer show - IP address unhealthy: Resolution Guide
1,661
Visibility:
Votes:
4
Category:
ontap-9
Specialty:
dp
Last Updated:
Applies to
  • ONTAP 9
  • Cluster Peering
Issue
When a remote cluster's interfaces become unavailable, errors, EMS, and changes in the cluster peer health output are reported.
  • For example, the output below indicates that some of the nodes in cluster1 are unreachable from cluster2
cluster2::> cluster peer health show
Node       Cluster-Name                 Node-Name
             Ping-Status               RDB-Health Cluster-Health Availability
node1
           cluster1                    node1
             Data: unreachable
             ICMP: unreachable         true      true            false
                                       node2
             Data: interface_reachable
             ICMP: interface_reachable true      true            true
node2
           cluster1                    node1
             Data: unreachable
                                       node2
             Data: unreachable
4 entries were displayed.
  • The cpeer.unavailable EMS message is also reported each time the remote cluster becomes unavailable
cluster2::> event log show -messagename cpeer.unavailable -instance
           Node: node1
      Sequence#: 71687
           Time: 5/15/2012 14:02:37
       Severity: ALERT
         Source: mgwd
   Message Name: cpeer.unavailable
          Event: cpeer.unavailable: Peer cluster cluster1 is no longer available.
  • When it becomes available again, no EMS message will be reported.
    • Each time the remote cluster transitions from available to unavailable, a message will be received.
    • There is an implicit transition to available between each cpeer.unavailable message.
New to NetApp?
Scan to view the article on your device
