NetApp Knowledge Base
Can a volume junction-path be renamed?
1,338
Visibility:
Votes:
0
Category:
data-ontap-8
Specialty:
core
Last Updated:
Applies to
  • Clustered Data ONTAP 8
  • ONTAP 9
Answer
Yes, the junction path to which a volume is mounted can be modified as follows:
1. Check the current junction path of the volume:
::> volume show -vserver <vserver name> -junction
Vserver     Volume       Language        Active     Junction Path     Path Source
nfs_vsvr    nfsroot       C.UTF-8           -             /                   -
nfs_vsvr    vol1          C.UTF-8         true           /vol1          RW_volume
nfs_vsvr    vol11         C.UTF-8         true          /vol1/vol11     RW_volume
nfs_vsvr    vol2          C.UTF-8         true          /vol2           RW_volume
4 entries were displayed.
2. Un-mount the volume whose junction path you wish to modify, for example vol2:
::> volume unmount -vserver nfs_vsvr -volume vol2
3. Mount it to the desired junction-path name:
::> volume mount -vserver nfs_vsvr -volume vol2 -junction-path /vol0 -active true -policy-override false
4. Verify the volume junction path has been modified:
nfs_vsvr    vol2          C.UTF-8         true          /vol0           RW_volume
Additional Information
Add your text here.
