NetApp Knowledge Base
"Volume delete" fails due to association with an Application
410
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9.8
Issue
Attempting to delete a volume with command volume delete results in the following error:
cluster1::*> volume delete -vserver vserver1 -volume volume1
Error: command failed: Volume "volume1" in Vserver "vserver" is part of application "application". You must remove the volume from application "application" using
"application volume remove" (privilege: advanced) command before you can delete this volume.
New to NetApp?
  • Was this article helpful?
