NetApp Knowledge Base
SolidFire Multi-Drive Slice Service (MDSS) node swap considerations
206
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
NetApp Element software
  • This article does not cover enabling Multi-Drive Slice Serivce (MDSS) on a cluster and is only used for guidance in node replacement scenarios
  • For clusters that are running MDSS, the drive in Slot 2 will need to be added to the cluster as a slice drive once the node replacement is complete
