Node and cluster UI are unavailable due to element-auth issue
Applies to
- Element Management Node (mNode), version 12.2
- NetApp storage cluster running Element Software on one of these versions:
- 11.3
- 11.5
- 11.7
- 12.0
- 12.2
- 12.3
- 12.3.1
- 12.3.2
Issue
- User is unable to access per-node or cluster UI after adding new / replacement node to the cluster or after cluster power off/on for maintenance.
- The
sf-element-auth.info
file shows that element auth is not in a ready state
element-auth[20976]: plugin_base.Exceptions.ServiceUnavailableException: The Element API command returned an API server error: Change API constant to be at least 20846 bytes
