NetApp Knowledge Base
How to place an Element storage node into manual maintenance mode (12.0 and prior)
1,863
Visibility:
Votes:
0
Category:
element-software
Specialty:
hci
Last Updated:
Applies to
NetApp Element Software versions 12.0 and prior
Note: The procedure below only applies to clusters running versions prior to Element 12.2; in 12.2 and above, a specific API method exists which replaces the manual steps below. See How to use Maintenance Mode in Element Software for details.
This KB will list the API calls to use for putting a node manually in maintenance mode while:
  • node is still part of the cluster
  • drives are not synced out
Handle with caution as it will put the cluster in a degraded state
New to NetApp?
