NetApp Knowledge Base
Element cluster UI shows old login prompt and has missing or incorrect icons post upgrade to 12.0 or above
280
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • Element Software
  • upgrade of Element cluster to 12.0 or above
Issue
After successfully upgrading a cluster to 12.0 or above, the cluster web UI at https://<cluster_mvip> accepts the cluster credentials and loads a functional UI, but some combination of UI elements is incorrect, such as:
1. The cluster is prompting for login via the older https auth method rather than redirecting to the newer login page (HCC).
  • old UI (incorrect for 12.0+):
  • new UI (correct for 12.0+):
2. a 'SolidFire' icon is in place in the upper lefthand corner of the UI rather than the 'NetApp' icon.
3. 'QoS Policies' is missing from the Management tab.
New to NetApp?
