502 - Bad Gateway error when loading the per-node UI of an Element storage node
Applies to
- NetApp Element software versions 12.0 and above
- NetApp SolidFire SF-Series product line
- NetApp H-series storage nodes
Issue
When attempting to access the per-node web UI (https://<node_management_ip>:442
) of an individual storage node on 12.0 or above, the UI fails to load and displays the following:
Something went wrong with Hybrid Cloud Control.
502 - Bad Gateway
Click the link below to try again. If the problem persists, contact your technical support engineer.
Example:
