Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
OnCommand Unified Manager backup failing with "Error Occured while creating backup archive /data/ocum-backup/databasedumps-repo/ocum_mysql_full_backup.sql.7z"
971
Visibility:
Votes:
0
Category:
oncommand-unified-manager
Specialty:
om
Last Updated:
Applies to
Version:
  • OnCommand Unified Manager 7.3P1 and above
Platform:
Note: We have seen this issue occurs in the following platforms
  • vApp
  • Linux
Issue
The error is seen in OnCommand Unified Manager "ocum-error.log" file.
Note: If you have downloaded the support bundle then the "ocum-error.log" file is located "\support_bundle\server\ocum-error.log"
If you want to see the "ocum-error.log" file in a live system, this file is located here
Linux/vApp:
/var/log/ocum/ocum-error.log
Windows:
\ProgramData\NetApp\OnCommandAppData\ocum\log\ocum-error.log
Error:
20XX-09-09 07:14:32,993 ERROR [oncommand] [taskScheduler-4] [Backup|ScheduleBackup][c.n.dfm.impl.backup.BackupArchiver] Error Occured while creating backup archive /data/ocumbackup/database-dumps-repo/ocum_mysql_full_backup_1536427804511.sql.7z
cause :
7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,64 bits,4 CPUs Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz (20651),ASM,AES-NI)
Scanning the drive:
1 file, 89533818092 bytes (84 GiB)
The following Error has also been found in the ocum-error.log:
20XX-09-05 05:37:10,214 ERROR [oncommand] [taskScheduler-2] [Backup|ScheduleBackup] [c.n.dfm.impl.backup.BackupArchiver] Error Occured while creating backup archive /data/ocumbackup/database-dumps-repo/ocum_mysql_full_backup_1567611844412.sql.7z cause :
7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,64 bits,8 CPUs Intel(R) Xeon(R) CPU E7-8890 v4 @ 2.20GHz (406F1),ASM,AES-NI)
Scanning the drive:
1 file, 223696067780 bytes (209 GiB)
Creating archive: /data/ocum-backup/database-dumpsrepo/ocum_mysql_full_backup_1567611844412.sql.7z
Items to compress: 1
System ERROR:
E_FAIL
20XX-09-05 05:37:10,214 ERROR [oncommand] [taskScheduler-2] [Backup|ScheduleBackup] [c.n.d.i.backup.BackupRestoreManager]
Error occured while compressing databse dump file or deleting it /data/ocum-backup/database-dumps-repo/ocum_mysql_full_backup_1567611844412.sql.
Full exception: com.netapp.dfm.impl.backup.BackupCreationException: Error occurred while creating backup archive /data/ocum-backup/database-dumpsrepo/ocum_mysql_full_backup_1567611844412.sql.7z.
New to NetApp?
Scan to view the article on your device
