Downloading support logs and exporting workflows fail with an HTTP 404 and other Errors in Workflow Automation
- 1,160
- Visibility:
- Public
- Votes:
- 6
- Category:
- oncommand-workflow-automation-wfa
- Specialty:
- legacy
- Last Updated:
Applies to
- Workflow Automation 5.1
- Workflow Automation 5.1.1, 5.1.1P2
Issue
- Support bundle and workflow exports are not downloadable from the UI as it fails with a HTTP 404 error
- Manual Backups via web UI and Backups via REST API are failing as well
- And one or more deployment files under the
deploymentsfolder are in a*.failedstatus.- Windows deployment files location:
$:\Program Files\NetApp\WFA\jboss\standalone\deployments - Linux deployment files location:
/opt/netapp/wfa/jboss/standalone/deployments
- The content of the failed deployment file looks like :
"{\"WFLYCTL0080: Failed services\" => {\"jboss.deployment.unit.\\\"download.war\\\".undertow-deployment\" => \"java.lang.RuntimeException: java.lang.RuntimeException: UT010039: Unknown authentication mechanism CUSTOM-BASIC
Caused by: java.lang.RuntimeException: java.lang.RuntimeException: UT010039: Unknown authentication mechanism CUSTOM-BASIC
Caused by: java.lang.RuntimeException: UT010039: Unknown authentication mechanism CUSTOM-BASIC\"}}"
- In the
server.logfile you will find this error:
