NetApp Knowledge Base
Cognos scheduled reports fail after password update: CM-REQ-4159 CM-CAM-4005 Unable to authenticate
4,584
Visibility:
Votes:
1
Category:
oncommand-insight-data-warehouse
Specialty:
ds_dii
Last Updated:
Applies to
  • OnCommand Insight (OCI) 7.3.x
  • Data Infrastructure Insights(DII)
  • IBM Cognos
Issue
  • After logging on to IBM Cognos Connection successfully after a password change, previously scheduled reports will fail, while other non-scheduled reports will run successfully during this session.
  • Following error message will be observed when scheduled reports fail:
CM-REQ-4159 Content Manager returned an error in the response header. The error "cmAuthenticateFailed CM-CAM-4005 Unable to authenticate. Check your security directory server connection and confirm the credentials entered at login" can be found in the response SOAP header. CM-REQ-4342 An error has occurred with the client.
CM-REQ-4159 Content Manager returned an error in the response header. The error "cmAuthenticateFailed CM-CAM-4005 Unable to authenticate. Check your security directory server connection and confirm the credentials entered at login." can be found in the response SOAP header. CAF-WRN-2082 An error has occurred. Please contact your administrator. The complete error has been logged by CAF with SecureErrorID:2025-05-30-20:00:00.499-#39 CM-REQ-4342 An error occurred with the client.
New to NetApp?
