Cognos scheduled reports fail after password update: CM-REQ-4159 CM-CAM-4005 Unable to authenticate
- 3,001
- Visibility:
- Public
- Votes:
- 1
- Category:
- oncommand-insight-data-warehouse
- Specialty:
- oci
- Last Updated:
Applies to
- OnCommand Insight (OCI) 7.3.x
- IBM Cognos
Issue
- After logging on to IBM Cognos Connection successfully after a password change, previously scheduled reports will fail, while other non-scheduled reports will run successfully during this session.
- Following error message will be observed when scheduled reports fail:
CM-REQ-4159 Content Manager returned an error in the response header. The error "cmAuthenticateFailed CM-CAM-4005 Unable to authenticate. Check your security directory server connection and confirm the credentials entered at login" can be found in the response SOAP header. CM-REQ-4342 An error has occurred with the client.
