What are the types of reboots and their differences on E-Series controllers?
Applies to
NetApp E-Series.
Answer
Soft Reboot
- Only reboots the processor and is the default reboot method
- Runs through firmware and does not issue a Power On Self Test (POST)
- Command example:
reboot
Hard Reboot
- Resets the entire board
- Bypasses normal reboot hooks in the code
- Runs through firmware and does not issue a POST
- Command example:
sysReboot
Hard Power on Event
- Only occurs when power is interrupted (power loss, powering off the controller)
- Field Programmable Gate Array (FPGA) registers are reset
- E-Series Controllers determine if a hard power on event occurred by checking the FPGA registers during Start-of-Day (SOD)
- Issues a POST
Additional Information
N/A
