NetApp Knowledge Base
Cinder driver does not properly initialize in Openstack Wallaby
801
Visibility:
Votes:
7
Category:
not set
Specialty:
snapx
Last Updated:
4/3/2023, 8:55:12 AM
Applies to
  • OpenStack Wallaby
  • Cinder configuration file /etc/cinder/cinder.conf defining a stanza with SVM credentials
  • NetApp ONTAP storage backend
Issue
Cinder driver does not properly initialize, with errors in /var/log/cinder/volume.log like:
2021-11-24 12:06:44.258 26 DEBUG cinder.volume.drivers.netapp.dataontap.client.client_cmode [req-xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx - - - - -] <== is_qos_min_supported: exception (0ms) TypeError('can only concatenate str (not "NoneType") to str') trace_logging_wrapper /usr/lib/python3/dist-packages/cinder/volume/volume_utils.py:1433
2021-11-24 12:06:44.260 26 ERROR cinder.volume.manager [req-xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx - - - - -] Failed to initialize driver.: TypeError: can only concatenate str (not "NoneType") to str
New to NetApp?
