Astra Trident
Astra Trident
Featured
Download the latest version
Download and install the latest Trident release from GitHub
Cross-Namespace Volume Access
Need to share volumes between Kubernetes namespaces? Now you can!
General Troubleshooting
Learn basic troubleshooting steps with Astra Trident
Other Resources
- Trident CSI Operator Installation Failure on OCP 4.21Thu, 12 Feb 2026
- nas-economy driver creates extra qtree pool volumesTue, 10 Feb 2026
- Unable to use Trident after using default endpoints in AWSTue, 10 Feb 2026
- Does the root_user access images in Trident ver 25.10.x?Mon, 09 Feb 2026
- Trident controller pod gets overloaded with high amount of PVC mountsMon, 09 Feb 2026
- Upgrading Trident Helm installation using private registry fails with RBAC errorThu, 05 Feb 2026
- How to Cleanly Uninstall Trident Installed with Helm for OpenShift environmentWed, 04 Feb 2026
- DB2 Restore Failure with Trident Protect: “No Space Left on Device” ErrorTue, 03 Feb 2026
- How to Change NFS Export Policy for Trident-Managed Volumes in OpenShift Without Disrupting Existing SetupMon, 02 Feb 2026
- Trident Controller Pod Initialization Error Due to Unreachable ONTAP BackendFri, 30 Jan 2026
- Is there a setting to enable advanced capacity balancing when creating a FlexGroup from Trident?Fri, 30 Jan 2026
- VM clone in Kubevirt fails to be created in a kubernetes clusterThu, 29 Jan 2026
- Which of the two Trident Operator 25.10.0 should be installed on OpenShift?Wed, 28 Jan 2026
- Trident 25.06.0 ontap-nas-economy is slow on deployments up to ONTAP 9.14.1 PxWed, 28 Jan 2026
- cli trindent-protect doesn't work in a Rancher environmentTue, 27 Jan 2026
- Is that possible to set Volume tags via TridentMon, 26 Jan 2026
- TridentProtect: Failed to promote AMR with error: failed to copy AppArchive: failed to read source's VolumeSnapshots from its AppArchive: The specified key does not existSun, 25 Jan 2026
- Do tridentnoderemediations and tridentnoderemediationtemplates work when enableForceDetach is disabled?Wed, 21 Jan 2026
- Kubernetes VM fails to attach volume when PersistentVolume is stuck in deletion state with reclaimPolicy set to DeleteMon, 19 Jan 2026
- Trident fails unstaging PVs on bare metal hosts with 25.10.0 releaseFri, 16 Jan 2026
- Clone of a PVC fails when using Velero backup SolutionThu, 12 Feb 2026
- Enable Certificated-based Authentication for a Trident backendTue, 10 Feb 2026
- OpenShift Virtualization VM in paused status with error: low-level IO error detectedSun, 08 Feb 2026
- Trident pod is stuck in a crashloopbackoff state and is unable to be usedFri, 06 Feb 2026
- Trident - LUN already mapped to initiator(s) in this group error after pod restartThu, 05 Feb 2026
- Unable to create backend - deferred syncing TridentBackendConfigThu, 05 Feb 2026
- Trident NFS mount.nfs: mount(2): Permission denied while trying to mount volume on podFri, 30 Jan 2026
