What are the recommended settings for Solaris 10 with Ontap?
Applies to
- Ontap 9
- Solaris 10
Answer
The setting remains same for Solaris 10 as compared to Solaris 11.x.
Additional Information
WARNING Note: Post HUK installation, Host reboot is required to ensure that the HBA parameters are set accordingly. |
- To complete the installation, you must configure the host parameters for your environment (Oracle Solaris I/O Multipathing or MPxIO in this case) by using the
host_configcommand. - The
host_configcommand has the following format:
/opt/NTAP/SANToolkit/bin/host_config ←setup> ←protocol fcp|iscsi|mixed> ←multipath mpxio|dmp| non> [-noalua] [-mcc 60|90|120]- With regards to
host_configsetup command for FC protocol,/opt/NTAP/SANToolkit/bin/host_config -setup -protocol fcp -multipath mpxiois the command that needs to be run on the host . - Other than that no other specific parameters are required.
