NetApp Knowledge Base
FC adapter down due to fixed port speed mismatch
722
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
Applies to
  • ONTAP 9
  • SAN
  • FC
  • Brocade Fabric OS (FOS)
Issue
  • SYSCONFIG-A shows adapter is down with status LINK NOT CONNECTED:
slot 2: Fibre Channel Target Host Adapter 2a
        (Emulex LPe32000 (LPe32004) rev. 12, <LINK NOT CONNECTED>)
  • FCP-ADAPTER.XML or network fcp adapter show -instance shows adapter's speed is set to 16G:
Operational Status    link not connected
Data Link Rate (Gbit)     16
  • NETWORK-INTERFACE.XML or network interface show -instance shows all LIFs on the adapter are down, with extended status LIF not initialized:
Operational Status    down
Extended Status    LIF not initialized
  • EMS log shows a link break:
Tue Sep 12 15:33:52 +0000 [node1: fct_tpd_work_thread_0: scsitarget.slifct.linkBreak:error]: Link break detected on Fibre Channel target HBA 2a with event status 1 , topology type 1, status1 0x0, status2 0x0.
  • Brocade FOS switchshow shows port is disabled due to throttling and speed is fixed to 32G:
Index Port Address  Media Speed   State       Proto
   4   4   010400   id    32G   No_Sync     FC  Disabled (Port Throttled)
  • Brocade FOS clihistory --showall shows the port speed was configured to 32G, without autonegotiation, at the same time as the link break:
Date & Time                      Message
Tue Sep 12 15:33:55 2023         admin, FID 128, 10.48.48.12, portcfgspeed 4 32
New to NetApp?
